Best directions to Hesston from Big Diamond area,Pottsville
Discuss Miscellaneous Fendered Car Racing
siggy99x
Re: Best directions to Hesston from Big Diamond area,Pottsville
Post by siggy99x » Thu Jul 24, 2008 6:30 am
rt 81 to 322 up past port royal to rt 22 lewistown take that till you get to rt26 go south on 26 the track will be on the right its about 2 1/2 hours. you can check out there website http://www.hesstonspeedway.com/
thenotoriousbjc
Post by thenotoriousbjc » Thu Jul 24, 2008 9:48 pm
get to the mcdonalds in huntingdon a little early and then look for a racecar hauler and follow it ......actually if you do what siggy99x said you will be able to find it no problem......there is a blinking yellow light at the intersection that you need to turn right at on 26....you will come to a stop sign turn right go about 50 yards make a left and then you will see it straight ahead on the left....if you are still worried pm me and I can send you my cell # incase you get lost but you should be able to find it no problem
