Small block one piece pan gasket without dipstick provision
mystic1582
Post by mystic1582 » Tue Apr 22, 2008 8:29 pm
Does anyone know of a Small block one piece pan gasket without the dipstick provision? My oil pan has no kick outs for the dip stick and the block has the kickout milled off..I really don't want to make a silicone mess out of this..Thanks part numbers would be appreciated. :bananadance:
garacingfan
Re: Small block one piece pan gasket without dipstick provision
Post by garacingfan » Wed Apr 23, 2008 12:05 am
:offtopic: ;)
GOSHOW
Post by GOSHOW » Wed Apr 23, 2008 2:30 am
Use the one piece silicone rubber gasket from Moroso. They are great gskts. the bolt holes have a metal insert so you don't crush the gasket out and it has a dip stick provision that is closed off on the inside so you can leave the excess hang, can't believe I said that, or cut it off with no leak. A little expensive but believe me after you use one you won't use another pan gskt.
RacerRose
Post by RacerRose » Wed Apr 23, 2008 1:14 pm
GOSHOW wrote:Use the one piece silicone rubber gasket from Moroso. They are great gskts. the bolt holes have a metal insert so you don't crush the gasket out and it has a dip stick provision that is closed off on the inside so you can leave the excess hang, can't believe I said that, or cut it off with no leak. A little expensive but believe me after you use one you won't use another pan gskt.
Fel-Pro has the same type of gasket too. Silicone with the "crush sleeves". I'll never use another cork gasket unless it's my only option.
2015 Race Counter
Hagerstown - 18
Winchester - 5
Williams Grove - 9
Lincoln - 3
Port Royal - 1
Susquehanna - 0
Path Valley - 1
Trail Way - 0
MIR - 1
Maple Grove - 1
39 races in 2015
https://www.facebook.com/brettroseracingengines
Finish Line columnist for The Journal-News Martinsburg,WV
GOSHOW
Post by GOSHOW » Thu Apr 24, 2008 1:34 am
Sorry my bad RacerRose is correct with the Fel-Pro pan gskt. Moroso makes the valve cover gskt's I use.
By the way cork is for plugging a wine bottle.
