It is currently Mon Jul 28, 2014 8:24 am
Post new topic Reply to topic  [ 1 post ]
PostPosted: Tue Apr 29, 2014 8:36 pm
1 - Winters 4:12 Internal Coupler Rear End FRESH (New Internal Coupler Assembly) - 500
3 - Feet Aeroquip #10 Blue Push-On Hose NEW - 10(all)
4 - Feet Aeroquip #8 Stainless Braided Hose NEW - 20(all)
5 - Push-On Fittings (2 #10 Straight Brass, 2 #6 Straight Brass, 1 #6 90 Degree Aluminum - 5(all)
1 - Racesaver 305 Steel Front Timing Cover - 10
1 - Box Misc. Racesaver 305 Front Timing Gears & Chains - 15
2 - MPD Wing Slider Valves - 25ea
1 - Set Aluminum Birdcages (Double Bearing RR) w/ Bearings - 40
1 - Maxim Aluminum RR Birdcage (Double Bearing) w/ Bearings - 25
2 - Straight Splined Pitman Arms (Bent Out for Header Clearance) - 10ea
1 - MPD 30” 975 LF/RR Torsion Bar - 15
1 - Sanders 30” 1000 LF/RR Torsion Bar - 15
1 - Sanders 30” 1025 LF/RR Torsion Bar - 15
1 - Sanders 30” 1000 RF/LR Torsion Bar - 15
1 - Sanders 30” 1025 RF/LR Torsion Bar - 15
1 - 26” Solid Titanium Driveshaft (16-10 Spline) - 40
1 - Set Aluminum Rear Axle Nuts - 15
1 - Winters Pro-Eliminator Stainless Shifter Bracket - 5
2 - Shifter Cable Quick Disconnects - 5(both)
1 - Frankland Large Rear End Plug - 5
2 - Winters Small Rear End Plugs - 5ea
1 - Red Driver Head Net - 5
1 - Steel Drivers Flat Rock Screen - 10
1 - Steering Wheel Pad - 5
3 - Steel .810 Inboard Brake Rotors - 10ea
Call or email Jonathon
(814)672-5121 NO TEXTS PLEASE
jnsmtrsprtsj3@aol.com
 Profile
Users browsing this forum: lmnine and 1 guest
