It is currently Tue Jul 29, 2014 9:00 pm
Post new topic Reply to topic  [ 1 post ]
 Post subject: Parts List
PostPosted: Wed Apr 30, 2014 8:15 am
Need to sell it all! Feel free to make an offer on anything!
NIB Liberty (Scat) rods, part number HBR-5700-2, 5.700" Large journal H beam, with the upgraded ARP 2000 bolts. .927" STD. pin. $350
NIB set of JE SRP pistons part number 231301 for sale. New in box, nothing done to them. They are for a standard 4.00" bore, 3.48" or 3.5" stroke, 5.7"rod, Flat top with a compression height of 1.560". $400
(2) Steve Baker (Baker Oultaw Fuel Systems) Gas carburetors for sale. These are 750 Holley HP Based carbs with Billet metering blocks and bases. These do not have the Billet bodies. Were ran on a dirt late model, all aluminum super engines. $500 each
Used set of MSD 8.5 Super Conductor plug wires. HEI style cap ends. Run under header on a SBC. Very good shape. $30
(2) NEW Rons Fuel Injection black fuel pumps, size "0". Brand New. $400/each
NIB Nutter Pro Series lightweight dry sump oil pump, 4 stage for Bert/Brinn mounting set up. Accepts the fuel pump/power steering pumps on the back of pump. $750
Nice used set of Manley Pistons for a SBC. Used one season.
4.030" bore
Flat top
1.550" compression height (3.48"/3.50" stroke, 5.7" rod)
1/16", 1/16", 3/16" rings
.927" pin
Deep valve pockets
Cleaned, pin bore honed, pins polished-ready to install!
No damage. Will sell with a correct, new set of Perfect Circle Moly race rings included. $250
NIB Comp Cams solid mechanical flat tappet lifter set w/oil hole in foot, part number 800-16. $160
NIB Isky solid mechanical flat tappet lifter set, no oil hole in foot, part number 202-H. $120
New sets of Valve Locks:
(2) NIB Comp Cams 10 Degree steel valve Locks set part number 613-16 $20 each
(1) NIB Howards Cams 10 Degree steel valve locks, part number 93017, 11/32" +.035" hgt. $15
(1) NIB CV Products 10 Degree steel valve locks, part number CV591, 11/32" +.050" hgt. $20
USED BUT VERY NICE Comp Cams Titanium Retainers, part number 730-16, no grooving from springs, 95% like new. 10 Deg., 1.437" OD, 1.065" outer step and .700" inner step.
Comp cams locks that were used with above retainers, part number 611-16. $80
Jeff
717-586-5332, call, text, or e-mail.
 Profile
